I am experiencing pixelation and stuttering using the Apple TV Channels DVR App, specifically when viewing HD channels. This is not noticably a problem when using the iPad app.
I have sent over a debug from the Channels DVR app on my Apple TV.
In terms of Apple TV Video settings, I am currently using the below on my 4K TV - previously these were set to 4K HDR as I have a 4K TV.
Format: 1080p SDR
Match Content: Range & Frame Rate
Channels App:
Deinterlacing mode: Linear (50fps) <— this is the same on my iPad
SDR Mode Switching: Off
I am using an HDHomeRune CONNECT Duo and an example of a HD channel on Tuner 0 is as below:
Virtual Channel: 104 Channel 4 HD
Signal Strength: 100%
Signal Quality: 89%
Symbol Quality: 100%
Streaming Rate: 4.022 Mbps
I have my HDHomeRun connected to a Gigabit switch which my Apple TV 4K is also connected to. This switch is connected over 10/100 ethernet to my wireless router in another room.
The iPad connects to the WiFi on the router.
FYI, Have just given InstaTV Pro a go and have no pixelation or stuttering with it.
Any suggestions to getting this working as I dont think this will pass for my wife otherwise!
