AppleTV: Context menu not tall enough when "View Previous Event" is in menu
When pulling up the context menu on recordings, if there is a "View Previous Event" menu option, the menu height isn't quite tall enough - the "Move to Trash" is just partially visible.
The context menu scrolls vertically.
Well, yeah… sorry if i wasn't clear. It just looks a bit weird to have to scroll down to have that final menu item fully display.
We don’t control the size of a context menu, the system does.
