AppleTV Dropped output frames causing transient stuttering
I'm having an odd issue with a few AppleTV units and video stutter/judder.
Stats show dropped output frames but if I pause the video or bump back then things clear up and the number of dropped frames stops increasing. (Or resets when I bump back or forward).
I've sent a few diagnostics from the clients:
2022/08/17 16:30:59.398630 New diagnostic log submitted under 74861b6c-f86f-41ba-bd70-8b5741a09176
2022/08/17 19:48:45.729727 New diagnostic log submitted under a14eaa5e-ad38-4e3d-8a03-bb26a955c184
2022/08/17 20:03:47.175282 New diagnostic log submitted under 39640f58-8613-4a2f-97fb-2517e885da66
I've also noticed that my UST projector will sometimes go black like it's changing resolution/frame rate and will show it's res/rate display. Though that could be the projector since Vava is still messing with firmware for it.
Exp video driver?
Which model atv?
Ah sorry, I thought that would be in the client debug data.
All experimental drivers (vid/aud/interlace).
I guess its probably a tvOS 16 beta issue.
Okay, fair shout. I think I remember it happening on 15. I'll check on an iPad with 15 and see if there's anything that comes up.
