Please add the ability to automatically (and manually using the metadata editor) associate an imported show with a "network" or "channel". It appears this may be accomplished for recordings using "Channel" in metadata and associating its logo. This would be super helpful for making Collections, Playlists, and Virtual Channels using a Smart Rule. TVDB provides this information to Channels as seen in stream links, so it would be fairly easy to add this data to imported files as well. I'm currently accomplishing something similar using Labels, but it's a very manual process applying the labels to each series.
