I’ve noticed when I’m browsing the quick guide. Sometimes pictures don’t show and sometimes they do. If I back out and go back in. The pictures will display.
Is there a fix for this and am I the only one seeing this?
After some more investigation this is happening from the web and my iPhone too.
So I moved the install from 3 different places to test all resulting in the same behaviour on the server and all clients both Apple and Android.
VM
Docker
Synology Docker - (so the HD is local to the server. Thought was maybe it was a delay over the network.)
Is this a known issue?
Can you right click an image and copy its URL and paste in here as an example
No option.
Here is the web server browsing via Firefox.
Sometimes it just takes time to load or other times it’s backing out and going back in.
Did find one.
If I click on it the image comes up.
http://10.1.1.15:8089/tmsimg/assets/p165382_v_v12_ad.jpg?w=480&h=720
Any suggestions?
