Astits: fetching next packet failed: astits: fetching next packet from buffer failed: astits: reading 188 bytes failed
I received numerous errors recording show from Hulu TVE. My recordings from my HDHomeRun were fine and only the Hulu TVE recording were impacted. Error report cf2f170a-659b-4431-bf1c-27925e8761c5 has been submitted.
Here's a summary of the errors:
[TNR] Cancelling stream TVE-Hulu ch6xxx after no data was received for 2m0s
[DVR] Error running job xxx: failed after 34.610481164s: hls: temporary failure while downloading: hls: timeout while waiting for data
[ERR] ULK invalid: {"next_time": -1, "error": "The pt received must be greater than the last …d less than or equal to the returned next_time (48.0). We received 0.0."}
[DVR] Error running job 1712102400-15 Chopped: astits: fetching next packet failed: astits: fetching next packet from buffer failed: astits: reading 188 bytes failed: read /share/ChannelsDVR/Streaming/channels-cache-3694831126/108-7ac26a33172daa6cdfe3b70ccce74d00fbb8fa011560c85bbf2ad8e9af2a6868: file already closed
[DVR] Error running job xxxx: astits: fetching next packet failed: astits: fetching next packet from buffer failed: astits: building packet failed: astits: parsing packet adaptation field failed: astits: fetching next bytes failed: astikit: slice length is 188, offset 210 is invalid
[DVR] Error running job xxxxx: fetching next packet failed: astits: fetching next packet from buffer failed: astits: reading 188 bytes failed: Error: Invalid padding descriptor
[DVR] Error running job xxxx: segment out of range.
Here's approx 2 hrs from the log when the errors occurred:
Log File (pdf)
