ATSC 3.0 very slow to tune
Yes. tad faster, maybe 3 secs.
I would think a diagnostics throw-over is warranted at this point - hoping that rouses the devs (if not the traffic here)
I dont use hls and all of my atsc3 stations tune in 5sec or less. Astc1 channels tune in about 3 seconds. I wonder if the region and the way it is implemented is a variable?
Yeah - i don't use it either, and see similar performance, but my suggestion was to try to get some info for the devs and/or us, given that direct tuning from an HDHR is sort of "quiet" evidence-wise. The fact it actually helped is gravy, and probably gives a good finite route for investigation/fixing!
Isn't the point of a standard, is to be standardized? If every market varied a bit, then manufactures of tuners would have to include all such possible variations. Thought that what ATSC is, a standard. I get the Encryption is optional, but the way un-encrypted broadcasts are should be the same throughout, no?
To a point, yes. But, if you think about it, there will always be variability at the channel level - that's why i went where i did.
An ATSC1 example - even just the RF channel difference, especially if you flip from UHF to VHF, can make the experience between 2 otherwise identical channels VERY different, and both adhering to the same standard.
Still no 3.0 tuning time improvements? Grrrrrrrrrrr!
@speedingcheetah did you send on the diagnostics here? Can't blame lack of answering if not...
Yes, I have multiple times over the course of the last couple months
I don't know what they're spending their time on, but Android client bugs that were pointed out over 6 months ago have gone unaddressed.
I'm going to guess they're spending most of their time working on something else these days and just doing enough here to keep the lights on. They probably decided the end is nigh with TVE support thinning, cable card sunset, and ATSC 3.0 all on the horizon.
Right, but the biggest change has been identifying that HLS-fed items bypass this issue - that's fairly new and a good data point to point out.
Well, there went my only workaround for the slow tuning time.
Yea. I know, like i said. Have submitted diags, before and after, and during. Many times. Even sent support emails. Nothing. Devs do not seem to care or acknowledge this particular issue.
I also find out, that PBS, later this month is converting to ATSC 3.0 as well. So, even more of my local networks with be 3.0, no idea if they will be DRM or not, but would not be surprised.
It is just an annoyance level issue, at this point, however, as more of my market is going the 3.0 route, it will be a bigger issue for me as time goes on.
Can you make a 30s tuner capture from channel 105.1
Setting Original Quality Delivery to Stream should achieve the same thing. Is that not working for you?
But.. that would also affect everything, TVE and custom channels, yes? The previous setting only affected HDHR.
EDIT: Yes. setting that to Stream then forces all channels to go through the Server and shows HLS active.
I just want HDHR channels to, ideally, only just the 3.0 channels, but guess that is not possible as the settings does not detect the source attributes. If it did, it could see the ATSC 3.0 specs, and switch to HLS, if 1.0, then be direct.
But, for just the 2 3.0 stations, soon to me a few more though, rather deal with the tune delay than to affect all other 100+ channels.
Not sure why yall can't just figure out and fix the long tune issue... maybe it is as other's have mentioned, it just due to how my (and other certain markets) is? But that still not really a solution to say, never gonna fix this.
I'm willing to look into this issue if you can provide debugging information. I need a capture from the tuner to see if there is some issue specific to your market.
Capture? What u mean? A recording form the dvr? I have sent in diags from the client app several times, with and with out HLS enabled.
Does it work if you remove the slash after .22
