I have two HDHomerun tuners, a Connect 4K and a Flex 4K. While recording two OTA news shows I noticed the one from an ATSC 3 signal showed zero bps throughput.
Running Version 2022.10.06.2032
This is not a bug, but rather a limitation of the data provided by the tuner. The bitrate is not provided; Channels cannot show you something it doesn't see.
Here is SiliconDust's response to this:
I'm guessing they're using the bitrate from the transport stream parser (ts: line in the debug output). ATSC 3.0 channels aren't broadcast as transport streams so they don't run through that system and thus don't have a rate to show.
That makes sense, thanks.
I’ll see if there’s something we can do to detect this and hide it if it doesn’t make sense.
