ATV beta not skipping
Sorry wasn’t sure the best place to post this bug…but playing a recording with the new ATV beta if you try and skip forward the X seconds or back X seconds it simply pauses. Basically there is no skipping ability in the beta for me. I switch over to the stable regular release and the exact same file and location skip forward and back like normal.
What do you have your Streaming Quality set to in the app?
Home streaming is set to original. The other is set to 720/4. Same as on the stable version.
It’s like the fwd and backward side clicks don’t exist and it just pauses no matter what area you click on the touch pad
Can you try rebooting the Apple TV and see if it still happens?
Skips are working fine for me.
But when I try to click and hold to rewind/ff it pauses most of the time.
