ATV Channel Beta problem this morning
Noticed this morning a few glitches. I was watching a OTA channel on my HD Homerun Connect via Win 10 computer and VLC and when I put the same channel on my ATV the Win 10 computer picture froze. I guess it stole the tuner even though there was another tuner to take? Plus I wanted to check on a recording via the Win 10 computer. ATV is still playing in backround. I try to skip forward via the slide bar and the transcoder quits working. I try again and it states there is not enough memory. I go check the server running on a Win 10 computer and check the task manager. Processor was up to 80% and memory about 20%. I looked at the processes and found two ffmeg process using about 31% each. I don’t know if this i s a glitch but I think there should have only been one ffmeg running since only the ATV was running. I don’t know why it using so much processor too especially if the tv signal is just passing through the server first. Just figured I would report what I saw.
