How do you dismiss tuner reception problems pop-up during live tv watching
If i hit enter all it does is pause the show, then if i resume the message comes back a moment later and always stays.
Under settings
ty
can you make this a sever setting so i can deploy it easier.
Does the Playback > Signal Notifications not do what you want?
Sounds like your DVR server isn't up-to-date.
no, i am update unless the server has a issue reporting the current version
Please press-and-hold on the Check For Updates button in the Settings page of your DVR. This is available in the latest DVR pre-release.
ah, that makes sense, its coming out soon
great
I can wait until then
thanks so much
@racameron
saying your server is out date isnt good advice, rather saying the beta has it and should be out soon makes more sense and less misleading
