Got a HDHomerun Prime with a Verizon Fios Cablecard and I get my channels fine thru the HD Homerun App but when I try to view them via the Channels App on a Apple TV 4 all I get is weak signal. I removed the spiltter and plugged it right into my FIOS box and same results. Rebooted everything many times...
I also have a HDHomerun Connect and it works fine thru the same Channels app
Attached the system log and tuner status - any ideas?
