Audio and Video not synced in recordings
I am recently getting bad recordings, where the audio and video are not synced. Often near the beginning of the recording. Is there anyway to trouble shoot.
2024.09.10.2115 (apple iMac 13,2). HD homerun is the source.
The video recording goes out of sync on the AppleTV or a Mac, but if I watch the video right in the Channels web interface on the host it just pauses.
I would love to troubleshoot if it is just poor signal (Jeopardy -> ABC in Orange County CA, the dreaded channel 7 problem), or my DVR server's ethernet connection to the homerun. If the latter perhaps I would just buy a small synology and put it in the same cabinet as the homerun.
Can you watch the recording from the disk it's recorded to using VLC Player to see if it's out of sync?
Is it a HDHR OTA or HDHR Cable recording?
It is HDHR OTA. The VLC player is not out of sync. But it instead just stalls and has no video or audio for a few seconds (but says transcoder running). So it seems like there is something wrong with the recording itself. I am trying to determine if this is what bad signal looks like from my Antenna (which I likely cannot improve upon), or something I can address.
Unclear if VLC Player has an issue or not.
Where do you see (but says transcoder running)
Does it play in VLC Player?
Did you open the recorded file on your disk using VLC?
VLC also has the issue. There is something wrong with the recording. Is there a way to tell if the recording is poor because of poor signal. Or something else, like poor buffering on my iMac.
If it was recorded from an HDHR tuner, look at the Channels DVR log for the stats on the recoding.
2024/10/30 23:00:00.122311 [SNR] Signal statistics for "TV/Secrets of the Dead/Secrets of the Dead S22E02 Field of Vampires 2024-10-30-2200.mpg": ss=93%-94% snq=100% seq=100% bps=3972913,1162592-4173600 pps=340,99-358
Signal Strength ss=93%-94%
Signal Quality snq=100%
Symbol Quality seq=100%
Bits/second bps=3972913,1162592-4173600
Packets/second pps=340,99-358
The numbers are Average,Minimum-Maximum
Also there are buffer stats
2024/10/30 23:00:00.260558 [SNR] Buffer statistics for "TV/Secrets of the Dead/Secrets of the Dead S22E02 Field of Vampires 2024-10-30-2200.mpg": buf=0% drop=0%
I guess this is what we need to look at:
2024/10/29 09:17:50.367786 [DVR]   queued recording job for EP000023485527 @ Wed Nov 13 7:00:00PM on ch=[7.1] (1731553200-1)
2024/10/29 09:17:50.373970 [DVR] Waiting 9h42m9.626031s until next job 1730253600-1 Jeopardy!
2024/10/29 18:29:46.343082 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-0-603827893 at 0 (0.000000) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:29:46.362457 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f980ad04a40] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:29:46.362516 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f980ad04a40] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:29:53.217253 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f980ad04a40] Packet corrupt (stream = 1, dts = 7064875279), dropping it.
2024/10/29 18:29:53.217309 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f980ad04a40] Packet corrupt (stream = 0, dts = 7064929830), dropping it.
2024/10/29 18:29:53.245359 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f980ad04a40] Packet corrupt (stream = 2, dts = 7064889679), dropping it.
2024/10/29 18:29:53.302850 [HLS] ffmpeg: file1193-ip192.168.1.158:  Error while decoding stream #0:2: Error number -16976906 occurred
2024/10/29 18:30:05.761473 [ENC] Request for 85 is more than 10 from the last encoded segment of 35
2024/10/29 18:30:05.766939 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-0-603827893 after encoding 0 to 35
2024/10/29 18:30:05.770566 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-85-1716179755 at 85 (125.391925) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:05.786185 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fba73504c80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:05.786239 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fba73504c80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:05.786671 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fba73504c80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:05.787472 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fba73504c80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:05.787507 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fba73504c80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:08.290703 [ENC] Request for 163 is more than 10 from the last encoded segment of 87
2024/10/29 18:30:08.295886 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-85-1716179755 after encoding 85 to 87
2024/10/29 18:30:08.299323 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-163-3750272408 at 163 (243.459872) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:08.314615 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7feef3d04d80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:08.314679 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7feef3d04d80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:08.315116 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7feef3d04d80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:08.315939 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7feef3d04d80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:08.315970 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7feef3d04d80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:13.138621 [ENC] Request for 235 is more than 10 from the last encoded segment of 169
2024/10/29 18:30:13.144378 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-163-3750272408 after encoding 163 to 169
2024/10/29 18:30:13.148079 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-235-2940933140 at 235 (352.769076) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:13.163076 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fe144d091c0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:13.163173 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fe144d091c0] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:13.163631 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fe144d091c0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:13.164393 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fe144d091c0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:13.164410 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fe144d091c0] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:16.116349 [ENC] Request for 264 is more than 10 from the last encoded segment of 237
2024/10/29 18:30:16.122285 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-235-2940933140 after encoding 235 to 237
2024/10/29 18:30:16.126409 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-264-656063240 at 264 (393.493097) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:16.140712 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd2bce04700] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:16.140767 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd2bce04700] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:16.141213 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd2bce04700] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:16.141954 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd2bce04700] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:16.141971 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd2bce04700] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:16.168271 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2891092487/encoder-264-656063240 after starting from 264 without encoding any segments
2024/10/29 18:30:16.326849 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-266-712640261 at 266 (396.679608) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:16.340806 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fbc91e0ac80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:16.340874 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fbc91e0ac80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:16.341308 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fbc91e0ac80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:16.342075 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fbc91e0ac80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:16.342115 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fbc91e0ac80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:19.395099 [ENC] Request for 265 is lower than current start segment of 266
2024/10/29 18:30:19.400254 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-266-712640261 after encoding 266 to 268
2024/10/29 18:30:19.404193 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-265-1895909237 at 265 (395.094697) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:19.421892 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc6f4d04d80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:19.421944 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc6f4d04d80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:19.422393 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc6f4d04d80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:19.423207 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc6f4d04d80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:19.423234 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc6f4d04d80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:21.444348 [ENC] Request for 264 is lower than current start segment of 265
2024/10/29 18:30:21.449663 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-265-1895909237 after starting from 265 without encoding any segments
2024/10/29 18:30:21.453678 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-264-2021975978 at 264 (393.493097) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:21.468925 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f9405c0a700] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:21.468988 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f9405c0a700] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:21.469454 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f9405c0a700] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:21.470350 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f9405c0a700] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:21.470382 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f9405c0a700] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:24.348648 [ENC] Encoder stopped for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-264-2021975978 after starting from 264 without encoding any segments
2024/10/29 18:30:24.352308 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-269-2948881610 at 269 (401.501097) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:24.366650 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd549504c80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:24.366707 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd549504c80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:24.367140 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd549504c80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:24.367905 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd549504c80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:24.367931 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd549504c80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:27.003621 [ENC] Request for 334 is more than 10 from the last encoded segment of 271
2024/10/29 18:30:27.008630 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-269-2948881610 after encoding 269 to 271
2024/10/29 18:30:27.012315 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-334-3795870027 at 334 (500.583411) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:27.027238 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc021c0b0c0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:27.027304 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc021c0b0c0] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:27.027733 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc021c0b0c0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:27.028472 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc021c0b0c0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:27.028490 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fc021c0b0c0] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:29.400959 [ENC] Request for 544 is more than 10 from the last encoded segment of 335
2024/10/29 18:30:29.406675 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-334-3795870027 after encoding 334 to 335
2024/10/29 18:30:29.410586 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-544-1180779303 at 544 (808.757959) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:29.425622 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ff13ac0fbc0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:29.425672 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ff13ac0fbc0] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:29.426111 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ff13ac0fbc0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:29.426901 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ff13ac0fbc0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:29.426927 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ff13ac0fbc0] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:37.122565 [ENC] Request for 669 is more than 10 from the last encoded segment of 556
2024/10/29 18:30:37.127844 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-544-1180779303 after encoding 544 to 556
2024/10/29 18:30:37.131565 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-669-3000938188 at 669 (998.397421) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:37.146789 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ffbf6d04f80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:37.146846 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ffbf6d04f80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:37.147297 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ffbf6d04f80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:37.148050 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ffbf6d04f80] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:37.148067 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7ffbf6d04f80] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:39.921374 [ENC] Request for 818 is more than 10 from the last encoded segment of 671
2024/10/29 18:30:39.926417 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-669-3000938188 after encoding 669 to 671
2024/10/29 18:30:39.930283 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-818-2907580034 at 818 (1220.919720) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:39.945223 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd3df40b340] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:39.945277 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd3df40b340] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:39.945727 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd3df40b340] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:39.946468 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd3df40b340] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:39.946487 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7fd3df40b340] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:46.858508 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-2688061834/encoder-818-2907580034 after encoding 818 to 829
2024/10/29 18:30:46.896300 [ENC] Starting encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-3725304200/encoder-832-4211766923 at 832 (1241.640422) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
2024/10/29 18:30:46.910656 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f7fa3504ac0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:46.910723 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f7fa3504ac0] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:30:46.911172 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f7fa3504ac0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:46.911913 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f7fa3504ac0] Packet corrupt (stream = 1, dts = 7225118479), dropping it.
2024/10/29 18:30:46.911947 [HLS] ffmpeg: file1193-ip192.168.1.158:  [mpegts @ 0x7f7fa3504ac0] Packet corrupt (stream = 2, dts = 7225118479), dropping it.
2024/10/29 18:31:21.141036 [HLS] Stopping inactive session file1193-ip192.168.1.158
2024/10/29 18:31:21.147655 [ENC] Stopped encoder for Jeopardy! S41E36 2024-10-28-2200.mpg in /Users/tdlong/Documents/DVR/Streaming/file1193-ip192.168.1.158-3725304200/encoder-832-4211766923 after encoding 832 to 898
2024/10/29 18:59:58.861944 [DVR] Waiting 1.138057s until next job 1730253600-1 Jeopardy!
2024/10/29 19:00:00.124637 [DVR] Starting job 1730253600-1 Jeopardy! on ch=[7.1]
2024/10/29 19:00:00.746872 [TNR] Opened connection to 10902D8C/0 for ch7.1 KABC-DT
2024/10/29 19:00:00.760385 [DVR] Recording for job 1730253600-1 from 10902D8C ch7.1 into "TV/Jeopardy!/Jeopardy! S41E37 2024-10-29-1900.mpg" for 29m59.875207s
2024/10/29 19:00:03.324945 [IDX] Generating video index for job 1730253600-1
2024/10/29 19:01:36.099729 [TNR] Cancelling stream 10902D8C/0 ch7.1 after no data was received for 6s
2024/10/29 19:01:39.680496 [TNR] Closed connection to 10902D8C/0 for ch7.1 KABC-DT
2024/10/29 19:01:40.178273 [SNR] Signal statistics for "TV/Jeopardy!/Jeopardy! S41E37 2024-10-29-1900.mpg": ss=88%-89% snq=93%,92%-94% seq=100% bps=5747262,1764192-9381952 pps=492,151-803
2024/10/29 19:01:40.703634 [SNR] Buffer statistics for "TV/Jeopardy!/Jeopardy! S41E37 2024-10-29-1900.mpg": buf=0%-1% drop=0%
2024/10/29 19:01:40.705392 [DVR] Job 1730253600-1 Jeopardy! ended prematurely: 28m19.29461s
2024/10/29 19:01:41.216646 [DVR] Starting job 1730253600-1 Jeopardy! on ch=[7.1]
2024/10/29 19:01:41.216731 [DVR] Waiting 23h58m18.78327s until next job 1730340000-1 Jeopardy!
2024/10/29 19:01:43.312349 [ERR] Failed to start stream on channel 7.1 via 10902D8C: HDHomeRun: 901 Tuner Unreachable: Could not tune to http://192.168.1.188:5004/auto/v7.1 after 30s
2024/10/29 19:01:43.312428 [DVR] Error running job 1730253600-1 Jeopardy!: could not start stream on channels=[7.1]: HDHomeRun: 901 Tuner Unreachable: Could not tune to http://192.168.1.188:5004/auto/v7.1 after 30s
2024/10/29 19:01:45.002504 [DVR] Starting job 1730253600-1 Jeopardy! on ch=[7.1]
2024/10/29 19:01:45.002586 [DVR] Waiting 23h58m14.997414s until next job 1730340000-1 Jeopardy!
2024/10/29 19:01:47.137134 [ERR] Failed to start stream on channel 7.1 via 10902D8C: HDHomeRun: 901 Tuner Unreachable: Could not tune to http://192.168.1.188:5004/auto/v7.1 after 30s
2024/10/29 19:01:47.137224 [DVR] Error running job 1730253600-1 Jeopardy!: could not start stream on channels=[7.1]: HDHomeRun: 901 Tuner Unreachable: Could not tune to http://192.168.1.188:5004/auto/v7.1 after 30s
2024/10/29 19:01:49.691048 [DVR] Starting job 1730253600-1 Jeopardy! on ch=[7.1]
2024/10/29 19:01:49.691159 [DVR] Waiting 23h58m10.308842s until next job 1730340000-1 Jeopardy!
2024/10/29 19:01:54.091718 [TNR] Opened connection to 10902D8C/0 for ch7.1 KABC-DT
2024/10/29 19:01:54.092071 [DVR] Recording for job 1730253600-1 from 10902D8C ch7.1 into "TV/Jeopardy!/Jeopardy! S41E37 2024-10-29-1900.mpg" for 28m10.308834s
2024/10/29 19:12:39.222603 [SYS] Created database snapshot: backup-20241030.021238
2024/10/29 19:12:39.222816 [SYS] Removing old backup backup-20240930.015557
2024/10/29 19:30:00.015910 [TNR] Closed connection to 10902D8C/0 for ch7.1 KABC-DT
2024/10/29 19:30:00.778732 [SNR] Signal statistics for "TV/Jeopardy!/Jeopardy! S41E37 2024-10-29-1900.mpg": ss=87%,86%-88% snq=93%,91%-95% seq=100% bps=5969232,1997312-12525312 pps=512,0-2076
2024/10/29 19:30:01.341127 [SNR] Buffer statistics for "TV/Jeopardy!/Jeopardy! S41E37 2024-10-29-1900.mpg": buf=0% drop=0%
2024/10/29 19:30:01.341388 [DVR] Finished job 1730253600-1 Jeopardy!
2024/10/29 19:30:02.124640 [DVR] Processing file-1194: TV/Jeopardy!/Jeopardy! S41E37 2024-10-29-1900.mpg
2024/10/29 19:30:02.124675 [DVR] Waiting 23h29m57.875326s until next job 1730340000-1 Jeopardy!
2024/10/29 19:30:03.567223 [IDX] Generating video index for file-1194: TV/Jeopardy!/Jeopardy! S41E37 2024-10-29-1900.mpg
2024/10/29 19:30:08.706435 [IDX] Finished video index generation for file-1194 in 5s
2024/10/29 19:39:38.866917 [ENC] Starting encoder for Jeopardy! S41E37 2024-10-29-1900.mpg in /Users/tdlong/Documents/DVR/Streaming/file1194-ip192.168.1.158-3537279786/encoder-0-3754605481 at 0 (0.000000) (encoder=h264_videotoolbox, codec=h264, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3916, segment_size=0.01)
The only issue I see is Channels DVR didn't receive anything from the HDHR tuner for 6 seconds, tried to reconnect three times and succeeded on the third try, 18 seconds after it disconnected.
Looks like you have a network problem between your Channels DVR Server and the HDHR tuner.
Do you see the logs for those PBS recordings?
You can view more than the last 1500 lines of the log https://getchannels.com/docs/getting-started/faqs/subscription/#how-can-i-view-more-of-the-channels-dvr-server-log
See this other users posts Cancelling stream after no data was received for 6s
I restarted my router. It turned out the HDHR tuner had a system update available, so I updated the HDHR. Then I waited for a week worth of recordings (hence the delayed reply). The problem has seemed to have gone away.
Clearly looking at these logs is helpful!
Thanks for the help.
