Audio choppy OTA HDHR
First, this is my living room setup: Apple TV 4K feeding into LG C3. C3 feeds Sonos Arc via eArc. AppleTV gets OTA from HDHR. All connections are ethernet and on the same network switch, which has been changed out as a test as were the cables.
As a side note I also have 4 Apple TVs in other rooms.
On the living room gear I have always had to keep the audio setting in Channels set to Legacy, If I put it on Default all my OTA stations start to get choppy audio. TVE feeds are always good. No other Apple TVs have this issue with OTA and they all are set to Default.
No other sources such as Netflix or Disney have any audio issues with my setup.
I experimented with putting the Apple TV into 16 bit audio only, and that cleared the issue, but doing that prevents the AppleTV from passing ATMOS audio on streaming apps. So not a good fix but maybe a clue?
So the whole reason I am trying to get this to work in Default is because my local Fox station has gone Dolby Atmos for their 3.0 feed, and I would like to be able to use it, but the Legacy audio decoder does not handle Atmos and passes no sound. I have to use Default.
So looking for ideas as to what is the issue with Default audio and 16/24 bit audio switching with OTA. I think the issue is OTA is 16 bit but other sources are 24 bit and something get hung or does not signal the ATV that it needs to change modes.
If you pause or seek back does the choppy audio stop?
Yes, a pause then play clears it.
@tmm1 so does that mean anything?
Yea, could be.
Does it happen every single time on HDHR channels? If its random, how often? Like 50% of time?
Can you submit diagnostics next time
It's very random. But when it does happen changing channels does not matter, it happens on every HDHR channel. I did try pausing like you suggested and that did work. Will submit next time I hear it.
happening now. just sent in the logs from the DVR and from the AppleTV.
84b8aaff-b43f-4ea0-905a-be7a8bac298e
Well those logs may not help. Seems the breakup I was hearing today was a problem with the local NBC station. When it got bad on the HDHR I went over to YTTV and heard the same thing. So I will resend when I hear it on another channel.
Ok, finally got around to this issue again. Just sent in a log from a choppy audio event at 7:50am CST. Pressing pause and then play clears it for a few minutes but then comes back.
I've discovered some recurring issues with audio and my apple devices. I am using an HDHR Prime and been trying to track down the cause but no luck so far. My issue is not identical to yours, but after thoroughly testing there is something wrong with the HDHR/Channels/Apple set up. I monitored the AppleTV logs using the Xcloud dev tools and couldn't see anything of note so at this point I guess it just is what it is.
Just curious, if you try and non-apple device do you have these issues? I found that I did not have any issues with my FireTV.
