Not sure why this is happening, but for the last month,It’s been doing that more and more. It started off gradually did it seem to do it a lot now.
If I watch things on the HD homerun app, that never happens.
Any ideas?
This is live tv using the guide, not a recording from library…
I've noticed this also but I don't think it's happening in the latest TestFlight. Can you confirm?
are you using the experimental audio driver?
Yes. I am using the experimental driver. Good or bad?
We're seeing a bug like this with it. Mostly with TVE. We're tracking it.
I have noticed this in Channels with the default audio driver, but I have also noticed it in both Hulu and Netflix, too. Makes me think it might be an OS-level issue, rather than a Channels issue.
(I remembered I sometimes see this in the morning with the KTLA news feed when watching live. Also, this seems to happen during regular playback at commercial transitions; sometimes a silent placard is shown during a break, and there is no audio when the stream switches back to the program.)
I had it set to experimental, but I’ll switch it to default and use it for a while and see.
Sadly, I’m not real techy anymore, but can usually plod my way through a problem, just slower than most. Lol
Any help is appreciated.
Maybe this fixed it. It seems to be working with no audio problems.
Crossing fingers..
Don’t know if this matters but I just observed the issue watching content recorded from Pluto. So maybe not only TVE. I’m was watching on AppleTV and submitted diagnostics just in case it’s helpful.
I believe the comment about TVE was meant to differentiate OTA/cable broadcasts (physical tuners) from internet streams, not specifically TVE only.
All good. If I see something that departs from the current narrative, I call it out just in case it’s important. Otherwise, it won’t hurt my feelings.
