Audio only channel tuning delay
I have added a few radio channels from satellite via Tvheadend and notice there is a considerable delay in tuning them compared to a standard channel. Can this delay be fixed? Is Channels maybe searching for a video stream? Thanks.
Can you make a sample recording?
If you play the recording, does it also have a delay?
Yes actually. The recording has a delay as well.
Okay please email the recording to [email protected]
Just sent. Thanks.
Can you also submit diagnostics from the app after playing the recording and experiencing the delay
Ok. Just submitted from Apple TV. Thanks.
