Audio only - missing pip icon
when using iphon 26 with ios 18 now 19.0.1
and choosing a channel the two squares ( i call it the pip icon) as this shines window and you can continue to surf or use other apps. then if i wanted i could swipe the mini window off screen but it would continue to play. this icon/option doesn’t appear???
background similar issues with video playback (minimize, pip window) after digging down, by changing play back video driver i got it to work again ( video ).
so i swapped audio drivers but that didn’t work like it did for video playback…
any ideas???
thanks in advance
Yes, I’m seeing this too or not as it were!
Audio only without the Picture in Picture which was working before Channels iOS 6.1
iPhone SE 2023 iOS 17.6.1
