In many TvOS apps, one may select the destination of the program audio (send program audio to a particular airplay speakers or set of speakers for example) via a swipe down on the remote and then from a menu selection. Would it be possible for this feature to be implemented in the Channels AppleTV app?
Would be an awesome feature… Especially so when you are having sync issues would be nice to not have to go all the way out and start over
That feature comes with using the system video player. We can’t use that. The other apps didn’t do anything to get it.
Since tvOS 13, you can do this via control center though. Press and hold the Home button on the Siri remote to bring it up. You can pick your route from there.
