I run my ATV direct to a Samsung/Harmon Kardon soundbar and then to the TV. Whenever I change channels the audio is not stable for the first few seconds, cuts in and out several times and then is fine. The picture is always stable. Does anyone else see this? I don't notice this on ATV's that only go to a TV using the internal speakers. Just on the soundbar.
I have tried all the drivers, turned the Match functions on and off and every other combination of setting I can think of to no result.
This does not happen with any other apps on the ATV. Even when changing from SDR to Dolbyvision on Netflix or any other source its stable. Stopping and starting programs on Netflix, Prime, Hulu is butter smooth. Only Channels seems to have an issue with the audio stream.
