Audio Sync w/noisy signal
Having an issue with audio out of sync. Recording from HD Homerun Flex 4K. Signal is pretty poor right now due to weather and season and so there are lots of glitches and digital noise that varies by the day. The audio gets out of sync. Stopping/restarting or jumping back can often force a resync that will hold for a while but often the next time there is a burst of digital noise, the signal gets out of sync again. Thoughts (other than moving closer to the broadcast antenna)? Same issue is occurring with the legacy and ATSC 3.0 signals.
Garbage in garbage out
Not much you can do besides invest in a better antenna
To be clear, the playback can play in sync and I can manually take action to force it to. The fact it gets out of and stays out of sync is a channels issue.
I've invested in and installed a better antenna but this is what I've got right now. I'll take ownership with the digital noise but the fact that Channels gets out and stays out of sync is a Channels deficiency.
