i have over a dozen seasons / movies of scooby doo content being auto added using the smart rules tool. is there a way to filter these titles out? Is that not the function of the title option?
Title matches the title of episodes. But you have a rule set to series. Which means it will only match whole shows with the rules.
how would i import series minus those with specific titles?
I’m not really sure what you’re trying to do or what the problem is.
But if you’re only trying to add a few different shows, maybe it’s easier to just pick them manually rather than using Smart Rules.
