Not really. If those shortcomings are acceptable, then you may be happy with the CCGTV. The limited RAM means that returning to the Home Screen takes a little longer, as it has to repopulate. Also, you can always use a different Bluetooth remote to get needed features.
I still have some issues with flickering with some video decoding on the TS4K that aren't present with the CCGTV (especially with TVE Discovery network streams). If the limitations don't turn you off, go for it. (Also, if you get the CCGTV w/ Netflix bundle, figuring in the cost of 6mo of Netflix, the device is only $15.)
If the remote is a big part of your decision, then the TS4K may be the device for you.
