Although @tmm1 doesn’t recommend J1900 CPU (due to age of chip) in his latest post “NAS Recommendations”:
Another viable (low priced) 4bay NAS from Qnap:
The TS-451+ does use the older J1900 chipset
I was looking to build a "Hackintosh Mini" so I got an older HP8300 USDT business machine on eBay (10"x10"x3"). It came with an i5-3475s, 8G RAM, a 128G SSD, and a 256G HDD. It was $170 shipped. It has turned out to be a great machine for Channels DVR. I just plugged in a portable USB 3.0 drive I already had for the recordings. There are lot of these HP8300 machines - and also the Dell Optiplex 7010/9010 machines - out there on eBay and Amazon for less than $200. Mine came with Win 10 and I added OSX to it. But you can run them with anything you want. I was going to get a new Intel NUC but this seemed like a better option and - so far - it has worked out very well. And you can also choose the other form factors for these - SFF, Mini-Tower, or Regular-Tower.
What is the speed of the NIC on these ?
The HP8300 has an Intel 82579LM Gigabit card. But I actually just use a $20 Wifi Range Extender (with an Ethernet port) because we don't have a wired connection in the room where the machine lives. I get about 70 mbps which is more than enough.
Just thought I would update the status of my channels build as it is pretty unique and I want people to know it can be done.
My Server is currently running on an HP DL360e Gen8 server. Virtualized Windows 10 using ESXI as the hyper visor. I am passing my Nvidia Quadro p2000 through to the VM.
My storage is being shared from my FreeNas server over the network.
I just ran a test 3 local Apple TVs, 4 remote ios devices, and 1 remote Apple TV. Everything was smooth.
If anyone has questions let me know.
I've been using Channels now for short while. I am happy and staying. I cancelled my Cable TV service with Cox after 20+ years including 15+ years of HDHomeRun legacy and Extends plus 10+ years with 3x HDHomerun Primes setup with BeyondTV (old throw back for those that know SnapStream) and WMC when Cox went full DRM. We are a household family of 5 and we watch a lot of TV.
For Channels setup, I've been using a Synology 1813+ 4GB ram and 36TB storage. works well, but I also use this NAS as my backup storage for the house. (we/I am a data hoarder for pics and media). I have been able to record 4-5 TVE streams simultaneously with no real issue to note. I'm just concerned of overworking it when 9TBs of data backups are happening.
So, I traded some old server equipment for a used QNAP TS-253Be-2G unit. I upgraded it to 16GB ram with 2x 6TB Raid-1 Iron Wolf drives. I plan on using this as my Channels DVR server with no other purposes.
Can I expect this QNAP to perform well for my needs? is there something I should setup/config to get better performance?
Any helpful suggestions are welcomed.
here is some info on QNAP ....
Thank you, I've already setup Channels properly on the QNAP with firmware 5.0 and did a few test runs. I looked around the forum for a bit to ensure I was not completely blind-sided. I saw a few references for the QNAP 251+/451+ models so I was a little bit confident.
For anyone looking for cheap solutions I suggest ebay! I got my channels DVR running on an HP prodesk 400 G4 I was able to snag on ebay for $90. Has a 7th gen intel pentium with quicksync and 8gb of ram it came with. I threw a m.2 in for boot and am using a 4tb usb3 drive I had laying around. Works great!
I just started using Channels on a Synology DS220+ with 10GB RAM and it works way better than my old setup, which was a Raspberry Pi 4 with 8GB RAM.
What HDD are you using with your DS220+?
Different NAS (I use asustor) but I have Seagate Enterprise Exos x16 7200rpm. I have had very good luck with. Never had a failure. I haven'tbhad I/O issues.
Good bang for buck on storage. $16.50 per TB on Amazon right now. I currently have 5 EXOS drives between 2 devices.
I have a 2TB Firecuda hybrid drive installed at the moment. Planning on buying two 10 TB
Seagate Exos 7E10 drives at some point.
