Best TV provider 2025
It's time for me to move to another provider. Im leaning towards HULU Live as it comes with all the other disney stuff, but had YTTV for a long time as well as DTv Stream. Currently on another free 21 day trial of YTTV.
Any thoughts on who is the current best provider for TVE?
YTTV will be the last one standing.
Yeah most likely. But DTV stream still has lots more TVE support. its just so dang expensive :stuck_out_tongue:
Im likely sticking with YTTV but gonna try Hulu Live for a few days just in case
Hulu live is the crappiest of them all. I wouldnt use it if it were free. TVE auth with channels doesnt work and picture quality when you use the app with adbtuner is beyond terrible. Switched to YTTV and it is 1000% better
Thanks for the tip. it was terrible 3 or 4 years ago when tried it but was hoping it got better. Was just thinking since it came with D+ and ESPN+.... I won't bother with it then though.
Also, following a lot of your guides. Very helpful. much appreciated
DTV Stream really.
Thanks! I appreciate that.
I hear you on ESPN+, I think you can get that free with Verizon cell service if I'm not mistaken (if you use them already)
My best experience has been with YTTV and ADB Tuner and a couple of onn boxes and video capture devices.
I really wish the paramount channels were still available on TVE. I want the east coast feeds and YTTV has the west coast feeds here.
If you decide to go back grab a referrer link and use a new email so as to take advantage of new promotions.
Unfortunately VZ is terrible where I live, but thanks for the suggestion. Maybe just go ESPN+ anyway :slight_smile:
This is the direction I'm going now. About to post a server spec topic.
What you mean about referrer link?
