Exactly. Only networks that offer a linear live stream of programming that is accessible on their website with your login credentials have any opportunity to be added for Channels' TVE integration.
Is that with any provider? So if I get a local xfinity account I will get the same results?
I just seen that direct tv now (at&t tv) has lifetime...how are the getting it?
Yes. Any provider. Just because the channel is available from your provider, and just because they have an app/website, if there isn't a live stream on the website accessible with your credentials, then it won't work with Channels', ever.
ok thank you...that is good to know...
