Beta PiP issues
anyone else having issues when invoking pip? the app becomes unresponsive, freezes temporarily, input lag, and sometimes, it just crashes.
i sent an email to support a while ago, but i get no response. anyone else seeing this?
diagnostics submitted
thanks.
Since I seem to be talking to myself and support emails never gets replies, here is another bug just introduced.
Pip no longer goes full screen when watching a virtual channel by clicking on the program in the guide. You have to use the pip controls. This works fine in a non virtual channel.
Also, double click play to go to previous channel no longer works when hoping between two virtual channels.
Another diagnostic submitted in case someone decides to look.
Thanks.
Work to improve PIP is on-going. There is no short term solution.
I will take a look at the Virtual Channel bugs.
Thank you. It felt like pip was an abandoned and just left to rot since it’s a system implementation.
That’s good to hear. Thanks.
