BETA: tvOS/ iOS - Stack Movies into their Franchises
I went down this rabbit hole a little further, this time on the correct site :wink: asking the fine folks over at TMDB if they wouldn't mind adding "Ocean's 8" to the "Ocean's 11" Collection?
I was then invited to read this previous content report:
Hi! The collection was locked to prevent users from adding the spin-off to the collection: Overview - Collection Bible β€” The Movie Database (TMDB)
So, no, it won't be added, but at least now I understand the rationale behind such a decision, and it's a pretty thoughtful one. The way they're using "Collections," they only consider them to include true movie sequels. Their "Collection Bible" explains it all, and foreshadows "a proper 'Universe' feature in the future."
This should be resolved with the latest TestFlight beta:
You are not, or just duplicates for any reason:
:foot:t3: :foot:t3: :foot:t3:
:fire: :fire: :fire:
Please keep the thread on topic.
I’m having trouble with the franchises being identified. I’m sure it’s some issue with my library and the way my files have been ID’d in the system but is there an easy/appropriate way to go about fixing it? I have every star wars movie but none are picked up by this feature.
Did you try what @cyberskier posted 10 days ago?
Refresh the metadata on your movies.
I did try metadata refresh and I also went through and switched providers from gracenote to theMovieDB or vice versa. Nothing seemed to work. Sorry for not mentioning in OP.
I'm not using this, but I would think if your 9 Movie Titles match those 9 in the TMDB Star Wars Collection it should work.
Just wondering when this is going to go into the App Store version?
Thanks
We don't comment on timelines, but it should be soon.
Franchises are now generally available as they were delivered with version 6.2.
