Beta: tvOS & iPad Multiview
Option to time out the border on the main large screen after a period of time would be appreciated. If you're listening to one of the smaller screens, then maybe you don't want the border to time out, but the big screen makes it obvious where the sound is coming from which makes the border redundant.
Not sure if this is by design but thought to report it
AppleTV
Multiview on with at least 2 sources. Full screen looks fine when one source selected with no borders. Then, remove the other source(s) and the remaining single source keeps a border.
Yes this is by design.
Oh you mean the actual border. Thought you meant the padding.
Good catch.
A border time-out option would be gratefully appreciated for the main screen.
Maybe the option to make it a small animated speaker icon instead? I quite like the border myself but don’t have OLED burn-in to be concerned about. A fade-out interval sounds like a good idea too.
Maybe copy functionalities from the Apple TV+ MLS Multiview player.
1 - Visual grid option selection
2 - Add, remove, replace grid from the mini-guide
3 - Auto-hide the white border selection and show speaker indicator on active channel
Can we get a menu option to make multiview the default playback option on a per client basis?
My apple tv remote just died and the samsung remote wont let me long press :rofl:
When i switch to roomy spacing there is a black border. One way to get around it?
2 posts were split to a new topic: Using channels from Channels to make channels in Channels
@maddox Would you be willing to make the number of seconds a logo appears on the screen configurable? I find myself navigating away, and back, to multiview channels just to see their channel logo again.
The bottom row guide in multiview for custom sourced channels do not show the program title as they do for hdhomerun or tv everywhere sourced channels. They do show in the quick guide, it’s helpful when looking for the correct game to add.
Can you provide a screenshot to show what you mean?
This is resolved in the latest TestFlight beta:
is there a way (or might it be in a future upgrade) to have the ability to 'cast' or 'airplay' from my iPad beta app to my TV?
Right now I can use screen mirror, but that locks out the ability of my TV utilize the zoom aspect ratio to fill in what I believe to be considerable gaps in the screen. - top/bottom/sides....
The ability to utilize the Multiview in the Chromecast app would also be a work around for me
captured on iPad but looks similar on apple tv.
This is likely because the third party source's guide data isn't providing the correct data.
Can you show what those channels look like in the Quick Guide of the regular video player, on Apple TV?
This is resolved in the latest TestFlight beta.
I will say though, you're going to have a rough time in Channels using the EPG data you're using. It's severely lacking the details that Channels relies on to give you a good experience.
It has no art, no metadata on shows, not season/episode information. Channels expects this to be there and uses it to power most of its features. For example, none of your channels will show in the pre-populated channel collections in Guide or On Now because the programs have no information like genre.
You wouldn't be able to create good Series Passes because the programs have no tags like "New".
We always suggest to just ditch your third party guide data and use what's built into Channels. Just manually map each of your channels using the manager by searching for and applying the correct network to each channel. Then you'll be using rich guide data and have an insanely better experience.
Source > Manage > Manage Lineup. Click the edit icon next to each channel.
Fixed build:
Thanks for the update, adding in multiview is easier now.
I agree using the Channels EPG data is a much better experience but the reason I don’t is because there are 2 countries in my imported channels that are not supported by Channels EPG data.
My only solution is to import Source1 twice and Source2 twice (they have the same curated channels list). Source1a (channels that are supported with Channels EPG data) and Source1b (channels from the 2 countries that are supported by the rough data). And the same for Source2a and Source2b. But each Source is limited by 1 stream. I’ll make the change but will this cause any issues when recording or using multiview when the server thinks there's a mix of 4 streams?
