BIG10 & FS1/FS2 - not entitled: mvpd: Resource is not supported by MVPD
Unfortunately it comes and goes, will work one week and then not work the next.
Seeing a different error on this one since at least yesterday: "foxsports matching item missing". Release 2025.07.09.0103
I am getting that error right now as well
Lol, Fox Sports the moving target. Y'all need to consider installing the E+TV container for Fox, it works great.
I wonder if the Channels DVR developers would be willing to get on top of that 'moving target' that you mention and get it working again? If it's not too much trouble of course.
Thanks for the suggestion. I am already running that as well as the vlc-bridge-fubo container to get them another way. I just happened to refresh my TVE channels sources and saw the same error, so I figured I would confirm the same error message, as it seemed like it might have been a new one.
Don't think it's a new error. I started seeing it 8 days ago
I'm sure other users have seen it before, along with all the other foxsports errors.
Not sure how I missed that. Guess I skimmed the topic too quickly.
I'm getting that error (foxsports matching item missing) on FS1, FS2 and BTN now.
FS1 [ERR] Failed to start stream for ch6197: TVE: foxsports matching item missing
FS2 [ERR] Failed to start stream for ch6198: TVE: foxsports matching item missing
BTN [ERR] Failed to start stream for ch6199: TVE: foxsports matching item missing
Logs have been submitted as 8d30d03d-fee2-4edd-9b18-97cbd6025a4f
Agreed, now the E+TV container is not working because it won't pull any Fox sports events. Something is going on.
Fox sports channels giving - foxsports matching item missing
I lost FS1. Did an update, deleted Verizon FiOS as source, re-added it, scanned twice, no FS1 or FS1. Any ideas?
v2025.07.13.0222 Working for me
Wow, working here too! Thanks so much for fixing this!
Updated to latest pre-release and still not working, error continues to be as listed in OPs title. The perpetual issue, in other words, so should not be marked as solved.
BTN, FS1 and FS2 are working for me at their website
and on two Channels DVR Servers running v2025.07.13.0222.
Submit diagnostic logs if they're not working for you.
It won't matter, same error been happening intermittently for months now and logs were submitted before. The error that was fixed was that Fox channels went away completely for all, it did not fix the OP and mine's error.
That's why it's not a solution for this problem. The other thread should probably have not been merged into this one in other words because it's two separate issues.
Prerelease fixed FS1 and FS2. There is no longer Fox network TVE channel. I'll just use the one on the cablecard. Thanks!
