BIG10 & FS1/FS2 - not entitled: mvpd: Resource is not supported by MVPD
Same behavior here. My local Fox TVE disappeared as well. I have other ways to get it like you so not a problem for me but could be an issue for others.
There is no longer Fox network TVE channel
Says who?
Yeah...theres a few FOX affiliates still on TVE. Still very unreliable tho and I would recommend using alternate to get FOX still.
What is the Op and mine's error?
What other thread?
You're being vague.
This thread has nothing to do with the local TVE Fox stations.
The Topic Title should tell you we're talking about Fox Sports TVE channels BTN, FS1 and FS2.
For local TVE Fox stations, see this relevant topic
2025/07/13 23:23:03.230143 [ERR] Could not start stream for TVE-hotwirecommunications_auth-gateway_net ch6198 FS2: TVE: not entitled: mvpd: Resource is not supported by MVPD
The error that got merged into this thread was 'matching item missing', had nothing to do with this long standing error that OP posted and will continue to exist intermittently.
Last replies from OP
@tmm1
What errors is this supposed to fix?
@Helios2
Are Fox Sports BTN, FS1 and FS2 working for you?
If not, unmark this post as the solution
I posted my log entry showing that this latest pre-release does not fix the mvpd issue. The fix is not a solution for this particular problem, it was a solution for the channels going away for everyone.
The topic issue is still an issue, and the log that I posted shows that. Even if you delete the source and re-add it, the channels might work for a while but the issue will come back. As of today mine are working, tomorrow might not again.
I'm not saying this is a channels issue and the channels dev told me they can't fix it. All I'm saying is that this issue is not fixed, whether it's on Fox's side or what.
You're the only one stating that.
If the OP ever posts back and says it wasn't a fix for the Topic issue, I'll move the posts to another Topic.
We haven't heard back from the OP yet.
Did you ever create another topic for your issue?
Yep FS1 and 2 gone which you locked and merged to this one. That's really the source of all of this nonsense, the threads should not have all been merged together. Some yes, but not all same issue.
I'm not the only one that has reported this issue.
OK, that Topic has been reopened
You marked it Solved on April 15th
This thread should really be part of that one because they're the same thing. The latest issue got mishmashed into this.
The MVPD errors do not affect everyone apparently
You might want to unmark your other Topic as Solved if you think it isn't.
So unsolve it, I don't know how. It obviously happened again.
Nvm figured it out
Hi all, OP here. It seems we are talking about a couple of different issues in this thread. My original issue was with FS1/FS2 and the B1G10 network not authorizing and giving some weird error messages.
I tried everything suggested to fix it, but ultimately completely deleting the source and re-adding it fixed the issue. Doing scans, or re re-scanning channels did not.
I just checked, and I can still view these channels now.
Thanks, so in all the time you tried since you deleted and added the source you never saw Fox sports channel loss? How often did you try? I see by your first post that you're only coming up on 3 weeks now, so keep trying and report back if you see the same error again.
Because from what I've seen the issue comes and goes, so deleting and adding the source for a fix may have just been a coincidence. Maybe not. For example, right now my channels work. Right after the latest pre-release fix they didn't. And that has been going on over and over again for months, with the error that you gave in your OP.
All three channels (BTN, FS1 and FS2) are working with my YTTV Provider on two Channels DVR Servers running CDVR v2025.07.17.0309 (one is Channels :tve docker image, the other is bnhf's :tve docker image).
A post was merged into an existing topic: FS1 and 2 gone
