Big10 TVE Network no longer showing on Dish Network
I tried a channel rescan, but the channel number of 6199 is no longer showing. Typically these would provide an error message, but now the channel is gone completely when managing the source.
Any ideas if there is a way to get this back, or try to add a channel manually?
I did get the channel to show up by doing another scan, but here is the error it is showing:
Any ideas on how to fix?
Keep rescanning after a while I have had the same error....
That worked, thank you!
