On channels 33- OTA SD channels, they are all buffering/pausing badly on my Shield, like it has poor signal. (this is not the same issue as the pausing, then 1 fps on other noted Sd channels in other thread of mine).
It DOES pixelate alot in the HDHR app on my laptop.
But the HDHR Quatro tuner reports for each station:
| Modulation Lock | 8vsb |
| Signal Strength | 88% |
| Signal Quality | 100% |
| Symbol Quality | 100% |
here are logs of the app in software decode and hardware. it does it in either mode.
I see lots of dropped frames and other errors /messages.
can someone give me some insight as to what that all means?
