Bug: Playback selection from guide fails with PiP enabled
With PiP turned on, if you pick a show that is already recording for the guide, then it will fail to pop up the window asking if you want to start live or play the recording doesn't appear. It showed up once after a reboot, but then after that it wouldn't show. Oddly, you can make it show by double pushing select from the guide, then after the full screen live windows comes up hitting back.
I went back and reviewed it and the issue isn't as bad as I thought. It only is a problem if PiP is up or the last channel viewed was the one with the recording. Is that expected behavior?
Thanks,
Josh
