Build 2024 (6.19.14) Loading …
Anyone else seeing a spinning circle with Loading in the middle of the guide?
It won’t go away but the app works normally. It is still present when getting out of a stream, force quit, clear cache and after a reinstall.
This is not happening with previous builds.
Diagnostics submitted from iOS and iPadOS.
Thanks.
I'm seeing it here myself
I submitted it in the testflight app.
Had to go back to using the stable version until this gets fixed.
Checking it out now
This should resolve the issue.
I just tried the new IOS build and problem was fixed.
