Built in Tailscale integration has been removed
In the latest pre-release, we have disabled and removed the built in Tailscale support. This has been done in the interest of security.
You can still access your Channels DVR Server host perfectly fine with Tailscale installed on your host.
For a while now, due to techcnical difficulties, we have been unable to ensure that the latest version of Tailscale is running inside of Channels DVR Server. In light of the current climate of security concerns happening across the Internet, programming languages, and open systems, we have taken the steps to remove Tailscale rather than let you run a pottentially insecure system.
If you rely on Tailscale for remote streaming, simply install Tailscale directly on the host system your Channels DVR Server is installed on. Connecting to your server will be the same as it was with the built in Tailscale.
We hope you understand why we're doing this and ideally we'll get Tailscale built back into Channels DVR Server soon.
Just wanted to chime in and say I really appreciate the due diligence here. Proactive security moves like this aren't always popular when features get pulled, but prioritizing system integrity over convenience is 100% the right call. Thanks for staying on top of it.
It didn't work well anyways. Its a waste of devs' time to support it and I'm shocked this didn't happened sooner. Just give people a guide to install real Tailscale on the main site and then you're done.
I just hope now the devs are more focused on implementing some more important features with this out of the picture
Should Remote streaming still work if you’ve never enabled Tailscale nor ever used Tailscale?
Yes because that doesn't involve tailscale at all. You're just forwarding a port on your router
If you have CGNAT-d ISP, then you'll need Tailscale
What is this?
I just read your edit and understand what it's for now. I'm not sure why you removed the description of what this tutorial was for, as it's not clear at all without it.
Please remove this from the thread and post it to it's own new topic, as it will be more useful on its own topic, then just simply link to it from here.
Thank you for this move- better safe than sorry …only took about 15 minutes to get back on Tailscale
Any plans to make this work through a reverse proxy?
That’s kinda the reason why I asked if there were plans to make it work with a reverse proxy. Not asking if there’s a way to do it right now. Works with Plex so no reason the devs can’t make it work with Channels.
Plus I think your method violates tailscale’s terms of use. If you’re doing what I think you’re doing.
Why so hostile? I said if you're doing what I think you are. Which you are not, so cool. All I asked was about using a reverse proxy to the devs. I use it with other stuff so would like to use it with Channels as well. No harm in having other options right?
Channels don't support reverse proxies. I tried to get it working with tsbridge but I couldn't view a channel from it. Other users had the similar struggles.
If you need more security if you're forwarding your ports on your router, then just enable 2FA. Otherwise, you can use tailscale
I have CGNAT so port forwarding isn't an option for me. I've gotten all my services working through Pangolin. Only one I can't so far is Channels. I mean I can but then there's the authentication/token thing so it's not so convenient. I have been using Tailscale. But just wondering if the devs would look into a reverse proxy option that's all. Not trying to cause any trouble.
You'll have to get a vote in on that front by opening a thread in the feature request section
Just note: devs in the past have refused to implement reverse proxies but they (probably) can be swayed if theres enough demand.
I have never used Tailscale.
I have only ever used Wireguard VPN back to my home netowrk.
Previously Via PiVPN (u can install in on any Linux distro)
Or lately, since i have Ubiquiti Hardware Gateway, Teleport VPN, or Wireguard VPN option
Just install Tailscale on the same machine you are running the Channels DVR on and access it with the 8089 port.
Any technical reason for them not wanting to implement reverse proxy? Tailscale is great if it's your device. But if you want to let your friends or someone that's not technical use your cDVR temporarily it's a little too complicated for some.
You have to ask the devs themselves @eric @maddox
I'm not one of them :smiley:
Reverse prox is much better than exposing Channels DVR to the internet which according to Shodan 4,276 people do. I do as well but I do not show up on this list. Reverse proxy can block plain http access and stop showing the certificate to anybody who connects unless they know the name:
https://www.shodan.io/search?query=ssl.cert.subject.cn%3A".u.channelsdvr.net"
EDIT: Subfinder finds and resolves 3106 subdomains
