Cable provider authentication failed
I'm getting this error on ch 6001 , 6003 on my YTTV channels setup. Worked fine a week ago. Can login using my credentials on CBS.com and ABC.com. PBS works fine
Submit diagnostics and email support
Logs have been submitted as f43ebd1a-4fa0-4ed9-b91d-b17cad32ace1
Did you receive it ok?
It says your google password changed 3 months ago? The DVR is still trying to use the old password. Did you see that message when trying to add YTTV?
Yes I did change it. Do I need to delete YTTV as a source and re add it to the server?
Yes
Ok will do..And thanks again
