Channels ends up being a really great solution if you can get a cheaper cable plan.
It’s better quality than streaming options like Sling, and its usually way more reliable. It’s also not limited by number of connections/clients. You can just do what you want.
Cable downsides usually end up being price and contracts and price hikes. But mostly it’s the hardware leases that cost so much. And with software on them that is painful!
If you can somehow avoid the first three, the lack of having to lease their hardware ends up saving a ton of money. Channels works fantastic with tons of channels and is a really great option if you want to keep cable.
You also have the option to get Channels DVR for $8 a month, which is a fraction of what a Cable provider’s DVR hardware lease is per month. And again, you get to do whatever you want with the recordings.
