Thanks, Guess if I had an external Sata drive I would have discovered it doesn't work. Just assumed if a USB drive works, eSata should.
Was this resolved? I am trying to set up a my Channels Server on an external ESata drive on Synology 920+ and similar to above I cannot point to the share that is created by Synology for it ("satashare") It only allows my to point to locations in Volume 1. Any assistance is appreciated!
Did you assign read/write permission for System Internal User channels to it?
Yes the permissions are good. I can't navigate to the share, channels can only see shares on Volume 1 and satashare is not, even if I create a subfolder that is a share.
I don't know then. I don't use any eSata drives on my Synology NAS.
One of the developers will have to help you. @tmm1
Did you get it working?
