Simple to explain issue with a hopefully simple solution.
Channels DVR on my Shield TV isn't functioning. Of the five programs I've tried to record over the past week, zero recorded. I'm getting the "failed: program missed" every time. I don't know if it's a setting, the DVR sleeping (I've done everything I can think of to make it stay awake perpetually), or something with the hard drive.
I'll gladly add details/setup if the solution requires more information.
EDIT: The portion of the log for the entirety of the recording process, with IPs [[X]]ed out. Not sure if the "broken pipe" prior to recording is related, but it's happened a number of times randomly throughout, mostly when not recording.
2020/12/20 02:37:38 write tcp [[XXXXXXXXXX]]->[[XXXXXXXXXX]]: write: broken pipe
GET /dvr/files HTTP/1.1
Host: [[XXXXXXXXXX]]
Accept: application/json
Accept-Charset: UTF-8
Accept-Encoding: gzip
Connection: Keep-Alive
Content-Length: 0
User-Agent: ChannelsApp/3.0.3 (Google Chromecast; AndroidTV 10 API/29; com.getchannels.dvr.app 112012236; en_US; America/Chicago)
2020/12/20 02:43:57.938697 [DVR] Waiting 3h51m2.061313506s until next job 1608467700-ch32.2 Sherlock Holmes and the Voice of Terror (1942)
2020/12/20 06:35:00.000897 [DVR] Starting job 1608467700-ch32.2 Sherlock Holmes and the Voice of Terror (1942) on ch=[32.2]
2020/12/20 06:35:00.683533 [TNR] Opened connection to 1074C7E7/0 for ch32.2 Movies!
2020/12/20 06:37:32.363990 [WRN] Buffer for 1074C7E7 ch32.2 is more than 50% full (clients=1, len=33555368)
2020/12/20 06:38:49.272687 [WRN] Buffer for 1074C7E7 ch32.2 is more than 75% full (clients=1, len=50331736)
2020/12/20 06:39:59.929457 [WRN] Buffer for 1074C7E7 ch32.2 is more than 95% full (clients=1, len=63754936)
2020/12/20 06:40:12.837889 [WRN] Buffer for 1074C7E7 ch32.2 is more than 99% full (clients=1, len=66439576)
2020/12/20 08:00:00.682763 [TNR] Closed connection to 1074C7E7/0 for ch32.2 Movies!
