I am getting cancelled streams while watching live OTA on both of my HDHomerun devices (connect and quatro). Here is an example of the error:
2024/10/05 10:29:17.706782 [TNR] Cancelling stream 1072D5CE/0 ch15.1 after no data was received for 6s
2024/10/05 10:29:21.059991 [TNR] Closed connection to 1072D5CE/0 for ch15.1 KADN HD
I had this issue months ago and it appeared to resolve on it's own. Some additional information:
- both devices are located in the same closet and are fed to a switch which is connected to the main hub in my office
- all Channels connected players view over wifi. These are Firestick and Android TV device. All are affected
- ChannelsDVR server is hosted on an i5 mini PC with 16GB RAM running as a Docker container. This PC has been running for over a year without issue
- The station that is being tuned that cancels can be restarted immediately and can play for hours without an issue and then it can happen again but may also happen minutes later
- Restarting the Docker container seems to lengthen the time between cancel occurrences but this may be coincidence
I am unsure how to even start to pinpoint where the problem lies. Does anyone have any advice?
Any help is most appreciated.
