Can't access DVR web UI
Is your NAS still at that IP address 192.168.0.112 ?
Yes
Can you access and view the log
No
Well then, I'll leave it up to the developers, unless someone else has an idea.
@tmm1
@eric
Any more ideas?
Probably you will need to remove and reinstall the DVR from the NAS, then select the restore backup option
Well, that worked, but it's taken 5 days to restore everything when it should have taken only a few hours.
And today, I can't get back on the server at all.
Do you have a failing harddrive?
No. The diagnostics say it's fine, and I have perfect FTP access and network access through my PC into it.
