I'm running DVR Server (v2023.09.13.2351) on my personal Win10 laptop where I run many other apps & programs. No problem with that scenario.
However, I cannot start the server while I'm running my VPN on the Win10 system. If I do so, the server fails to connect to my Tablo TV tuner (yes, I have 'Tablo Network Tuner Support' checked).
Thus, the server shows 'No source found'. Doing a DVR network scan fails to find the tuner.
As a workaround solution, I must shutdown the VPN - then do the network scan again which finds the Tablo tuner instantly. I then start the VPN and all is well until the DVR server is restarted for any reason either manually or via Win10 reboot, etc. To be clear, once the server has been started via this workaround, the VPN and DVR Server coexist and run together with no problem.
I'd much rather find a "real" solution to this problem rather than this bothersome workaround solution.
Is there a solution which allows me to run the VPN 24x7 without causing any problem for DVR server when starting/restarting or anytime? TIA
