I just had this happen. I was in the guide and clicked on a future program and nothing happened. no menu to set up a recording.
I shut down the app and Apple TV, restarted and no change.
Channels 4.3.1
Channels 4.3.1
I would recommend submitting diagnostics from the client after this happens. If you can share a picture or screenshot of the guide and indicate where you are clicking that would probably be helpful as well.
it is back working normally.
I sent a diagnostic file. there wouldn't have been anything to see in a picture, just the guide. when I clicked a program no record menu came up.
