Love the app, but since I’m beta testing I figured I’d do some testing:
Turning on CC doesn’t do anything. I’ve also tried changing the audio from English to Spanish (I don’t speak Spanish but just testing) and it doesn’t change the audio stream.
Here’s the mediainfo of a piece of the channel I just tuned to for testing it:
[code]
General
Complete name : /Users/timstephens24/Downloads/v811.mpg
Format : MPEG-TS
File size : 20.8 MiB
Duration : 11s 594ms
Overall bit rate mode : Variable
Overall bit rate : 15.0 Mbps
Movie name : Ellen DeGeneres Show, The
Law rating : TV-PG
Video
Menu ID : 441 (0x1B9)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Format settings, picture structure : Frame
Codec ID : 2
Duration : 11s 245ms
Bit rate mode : Variable
Bit rate : 13.7 Mbps
Maximum bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Active Format Description : Pillarbox 4:3 image
Frame rate : 29.970 (30000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.220
Stream size : 18.3 MiB (88%)
Encryption : PowerVu
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 129
Duration : 11s 584ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 spf)
Delay relative to video : -744ms
Stream size : 543 KiB (3%)
Language : English
Audio #2
Format : AC-3
Codec ID : 129
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Delay relative to video : -752ms
Stream size : 272 KiB (1%)
Language : Spanish
Text #1
ID : 289 (0x121)-CC1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Text #2
ID : 289 (0x121)-CC3
Format : EIA-608
Text #3
ID : 289 (0x121)-1
Format : EIA-708
Language : English
Text #4
ID : 289 (0x121)-2
Format : EIA-708
Text #5
ID : 289 (0x121)-3
Format : EIA-708
Text #6
ID : 289 (0x121)-5
Format : EIA-708
Stream size : 0.00 Byte (0%)[/code]
