I run Channels DVR on several devices on several different platforms - Android TV (Shield), Android Phone, iPads, iPhone, Apple TV, Fire TV. Yeap I pretty much have all the different platforms. The method to reorder favorite channels is a bit clunky, but the worst part is that I have to do it on every single device. It would be nice if I could set my favorite channels and what order I want to see them in on the server side, and then the clients would pick this up. That way I only have to do it once in an easier to use web interface.
This is already implemented:
I started to play with this feature a while ago but couldn't figure it out. I will give it another try. Thanks.
This is the way.
Thanks again for the tip. I figured it out and got it to work. This feature is great! Setting it up is a bit wonky and hidden, but it does work.
