My system is running great. It's on a GB hardwire connection. I wanted to see if WiFi would work equally well. I have 400Mb service and AC router. Speed test are the same wired or wireless. Anyway, I don't see anything in the Channels setting screen and in terminal mode ifconfig doesn't even work. So how would I change it? Hopefully if I don't like it I can easily change back to wired.
Thanks
Marshall
