I must be having a brain fart... I thought to change the order of the channels for AppleTv.. I go to On Now, click and hold the channel, select rearrange, they all jiggle, and then I can move the channel?
I no longer see any way to change the order.
It doesn't work in tvOS 14.3. We are waiting for 14.4 to come out of beta from Apple
So is this a recent change? How do I change the order for now?
You don't. Apple broke the behavior in 14.3, and the fix won't be released until 14.4.
So this is an Apple problem. Okay.
