Changing padding options seems to be broken
I've tried changing the padding to add time on multiple football games this weekend and the client will say that the padding has been changed, but if you look at the padding in the web admin interface it doesn't show anything. Changing it there fixes the issue. I haven't seen this issue on the Apple TV client. I had at least one recording with no padding that I missed the end of because of this.
I'm doing this from the scheduled recordings section and these games were all scheduled manually from either a football search or the guide, not with a pass. Latest 8/25 beta.
I think I figured out what the problem is - if you change the padding without selecting the adjust options button it won't take. In other words if you change padding and hit back to go back to the previous screen it won't work. But when you go back in to look at the scheduled recording later it will say the padding is there, because the client is cacheing the option. So it's a UI issue in the client - the client should always retrieve the current value from the server when you look at the recording, but right now it keeps whatever you set without change.
