Changing providers
I currently use YouTube TV as my provider. I am considering moving to Sling TV or another provider.
If I change providers, do I have to reconfigure my scheduled recordings on each device? Or do I just rescan once Im subscribed to the new provider and delete the subscription to YouTube TV?
Thank you
A little of topic but With Sling tv you don't get very many TVE channels if I remember right.
The scheduled recordings and passes are on your server and will still be there if you switch providers
Yes, that.
The only thing to be aware of is if you have any passes set to record on specific channel numbers, those might need to get updated.
Shouldn't matter. TVE channels have the same channel numbers regardless of the provider.
Right, but not all providers authorize the same channels. You could end up with more or less channels when you switch providers.
Yeah, I tried Sling again a few weeks ago, and the number of TVE channels you get with them is abysmal. Which is a shame because if they supported most if not all of their channels through TVE it would be perfect for me.
