Changing storage location
Hi, I've moved my DVR from my synology NAS to my Mac Mini and was storing recordings on the Mac (albeit very few as I've just moved over). I hadn't realised that I could store my recordings on my synology via network share but leave the dvr on my NAS. The original folders for the DVR are still on the NAS, should I just point the location to this? Or should I remove the DVR from the Nas and set up new folders?
We don't normally recommend recording to a network share. But if your devices are all hardwired it will probably work okay.
Remember to keep your bandwidth in mind when making decisions: USB2 has 480Mbps, USB3/3.0/3.1 has 5Gbps, and USB3.2 has 10Gbps; home ethernet has 1Gbps (generally).
If you know your network can handle it, it ought to be OK. (I used NFS shares on a NAS for DVR recording and had very little issue, even with multiple recordings at a time; as always YMMV.)
Thanks for both replies, I'll give it a go, should I just point the DVR to the DVR storage folders on the NAS from when I was using my synology as DVR?
Since he is using a Mac Mini as the Channels Host I would probably use AFP. At my office I had problems with SMB from Linux so I switched to NFS and the problems went away so a fan of NFS with Linux.
SMB performance could vary based upon the version. The version of Samba shipped is macOS is outdated IIRC, so that may be an issue ...
I know recent macOS uses SMB as the default for sharing. But I have found that AFP works better for all of us that connect to Synology File Shares over a VPN (normally 5 connections daily averaging 10 shares).
